My Clio 2004 does not start
15 years 1 month before #16966 by manual-mecanica
My 2004 Clio won't start. Posted by manual-mecanica
I have a 2004 automatic clio and in the morning I have a lot
15 years 1 month before #16971 by manual-mecanica
Manual-mechanics' response on the topic Re: My 2004 Clio won't start
First things first, check the filters and spark plugs. If everything is okay, check the temperature sensor to make sure it's not out of range. This is the first thing to check.
15 years 1 month before #17022 by manual-mecanica
Hi, I'm Alex. The problem you have is the steering wheel sensor (the RPM sensor).
15 years 1 month before #17035 by manual-mecanica
Thanks for replying. I'll take it to get checked and let you know. Okay, see you soon. : blush:
15 years 4 weeks before #17345 by manual-mecanica
Hello, they scanned it and found nothing, and I told the mechanic to change the crankshaft and temperature sensors, and it seemed to be working fine, but now the fan takes a long time to come on and it overheats to the point of leaking coolant. Could it be the sensors or something else? Thanks in advance for your help.
