Book laluz problems
15 years 2 months before #16515 by manual-mecanica
Laluz of the brakes published by Manual-Mecanica
(Opel Zafira 2000 dti 100cv year 2002) Hello greeting to everyone. I have a problem with the brake lights I do not work for me, I have looked at the mouse entrance and has a tension, the mouse has an open circuit when the pedal is at rest, that is, it lets go running and closed when I act on the pedal, that is, it does not allege the mouse supposedly the mouse I will go in that good way I have brought back in the lights and I do not like to know if the mouse or interrumer I would like if someone could facilitate an electrical scheme of this car thank you very much
15 years 2 months before #16517 by manual-mecanica
Manual-Mecanica response on the Re: problems with laluz brakes
Check the fuses first.
15 years 2 months before #16519 by manual-mecanica
Hello, in principle, thank you for answering
I have looked at the fuses and
what
is not well
15 years 2 months before #16520 by manual-mecanica
Hello in principle, thank you for answering I have looked at the fuses and they are fine that you do not know if the output of the mouse feed goes through the module I do not have the electrical scheme of the brake lights to be able to see if it passes through the electronic module if you have it please dim
15 years 2 months before #16521 by manual-mecanica
Hello, in principle, thank you for answering I have looked at the fuses and they are fine what you do not are if the output of the mouse feed passes through the module I do not have the electrical scheme of the brake lights to be able to see if it goes through the electronic module if you tubed it please dimin it, thank you very much.
