Suzuki Jimmy overheating 2005
15 years 2 months before #16502 by manual-mecanica
Suzuki Jimmy overheating 2005 published by Manual-Mecanica
Dear friends,
I request your help, for two years that I buy my Jimmy has the problem that the engine is left over when I have to climb an steep street or when for the reasons of the traffic of vehicles I remain immobile for several minutes and I do not pass the first, in normal conditions it does not heat. To date I have changed the thermostat and the Fan Clutch already gave the maintenance corresponding to the 80,000 km and follows the matter.
Now the mechanic tells me that it may
be necessary
15 years 2 months before #16506 by manual-mecanica
Manual-Mecanica Response on the subject Re: Suzuki Jimmy 2005 overheating
Indeed you have to give a probe (cleaning) to the radiator .......... Good luck
15 years 2 months before #16510 by manual-mecanica
Hello, compi, look at what fan it works ?, If it works, look at it also water pump can be a water pump failure or look at it thermocontact is on the refrigeration radiator, a piece more or less like a busy spark plug in the radiator, also verify if all these are well looked like a clutch joint can be some refrigerant loss.
15 years 2 months before #16516 by manual-mecanica
You have to check well I saw two great vitara suzukis, who were well but they warmed up when the exsijias a lot, steeps pronounced or very extensive tacos and both had a fissure in the multiple of admission and as it is refrigerated by water they lost water through ahy, the datelle is that it was only seen at the same time of the warm that they already told you and the last Czech this.
15 years 2 months before #16528 by manual-mecanica
Thanks for your estimated tips.
