Oil in the Diesel of Renault Clio Motor
15 years 1 month before #16425 by manual-mecanica
Oil in the Diesel engine of the Renault Clio Published by Manual-Mecanica
Hi, I have a Renault Clio Diesel 1.9 Frances, the problem I have is that I passed the water to the water, I change the cylinder lid and the problem persists, before I warmed now it does not do it but it continues to pass oil to the water. Please if anyone knows where I can find an engine schematical where the block plugs appear, I think that one is possibly oxidized. Any help will be well received thank you very much ...
15 years 1 month before #16428 by manual-mecanica
Hello Jorge, like the previous post of another user, I recommend you above all in French that you look where the oil filter is, if a heat exchanger has incorporated, if so, bridge their stalls and skip this exchanger and test this, it is very common that that fault is presented because of this element, especially in the Peugeot, Renault and Citroen, they usually put this component, check and warning.
15 years 1 month before #16432 by manual-mecanica
Good afternoon
check if you have Oil Cooler and you also have to verify the timing gear or trunk lid of time pine nuts
15 years 1 month before #16511 by manual-mecanica
Hi, surely you have to change a bind, greetings
14 years 9 months before #18515 by manual-mecanica
Hi Jorge I agree with the last answer, change the Board of the Curate
