Toyota Hilux Motor 2Rz, not part in cold
10 years 5 months before #49477 by manual-mecanica
Manual-Mecanica response on the topic Toyota Hilux Motor 2RZ, not cold in cold
The 2RZ Faith is 16v 2.4lt gasoline
I have the problem is Cuano accelerate, to accelerate from drowning and then revolutionize.
10 years 5 months before #49478 by manual-mecanica
The 2rz faith is 16v 2.4lt gasoline
I have the problem is when I accelerate, to accelerate from drowning and then revolutionize.
10 years 5 months before #49479 by manual-mecanica
It seems to me that you have a problem in the butterfly butterfly but if you want I can send you the manual and based on what the scanner tells you you check it
the other would be that you make a bridge in pin 13 and 4 and see how many times flashes the check light and let me know
8 years 10 months before #51922 by manual-mecanica
Good night .. know if this 2rzfe engine has MAP sensor ??? And where is it located .. ?? Thank you!!
8 years 9 months before #52022 by manual-mecanica
Hello the MAP sensor is installed in the multiple of admission the MAF sensor in the suction air hose one measures the precion and the other the flow greetings
