Motor refrigeration fan problem not for
14 years 10 months before #16113 by manual-mecanica
Hello everyone the problem I have is with a BMW 320 of the year 2000+O-. The problem you have is that the engine refrigeration fan is never stopped.
14 years 10 months before #16114 by manual-mecanica
Manual-Mecanica response on the Re: Motor refrigeration fan problem not for
Hi Julio, check the Electro relay almost certainly stuck, greetings. : Cheer:
14 years 10 months before #16142 by manual-mecanica
Czech the bulb of tenperature if bridge are activated, disconnect and deveria for if not for Czechs relay.
14 years 10 months before #16143 by manual-mecanica
Wait for a time if you are two thousand, you are injected, you have the check on if it can be the bad tennoun sensor, go your chek and if you do not prove what we told you.
14 years 10 months before #16148 by manual-mecanica
Check that the temperature sensor (CTS) is not disconnected, since in electronic injection vehicles when the sensor is disconnected, the fan is activated by the ECM as a prevention measure ...
