Doubt with vibration
15 years 1 month before #16065 by manual-mecanica
Doubt with vibration published by Manual-Mecanica
Hello, I request help to know what I can do with the next failure of a automatic Nissan Sentra Sentra, it is having vibrations in the engine and when there is no acceleration on some occasions it goes out, when starting it again it works again works again
15 years 1 month before #16067 by manual-mecanica
Manual-Mecanica Response on the Re: Doubt with vibration
Hi FloresGarcia, look, I think you start starting at the beginning, when did you perform the last tuning?, That is: change of spark plugs, air filters, oil and gasoline and motor oil, I also recommend giving cleaning to the distributor's lid on the inside, in the posts and in the brush since a kind of tartar accumulates and it is better to remove it for better contact and spark jump. I had a tsuru that after the tuning the engine followed it was composed only when I cleaned the distributor cover. What I tell you recommend that you be unveiled every 5,000 km unless your owner's manual says something else. Well when you have made the tuning to see how you go and tell us. LUCK.
