Loss of power in Megane 1.9dci 2001
14 years 4 months before #23343 by manual-mecanica
Manual-Mecanica Response on the Re: Loss of power in Megane 1.9DCI 2001
Yes. I don't have it anymore.
It is a very interesting appreciation of the fuel pump. I didn't know that I was not mistaken.
I also convinced me about the electronic accelerator, well the accelerator potentiometer ... but hey, I kept the doubt, because acting on different things worked well for a few days and then did the same again.
14 years 4 months before #23347 by manual-mecanica
The megane dci, is it disel or gasoline ???
14 years 4 months before #23366 by manual-mecanica
It was diesel. 105CV.
12 years 6 months before #41322 by manual-mecanica
I checked the cables of the injunctors to me the same thing happened to me and it was because three of the eSoso cables were wrong with Canvia them solutions I hope it will also serve you a council not fences to Renault to look for them would cost you about 600 euros more or less the best thing you can do is if you are a bit maniotas is to buy anthory cable two connection terminals of the little ones for each one that you have and change it and change it in that way Try to look at the cables and if it is the case, the fault can cost you about 50 or 60 cents and 20 minutes of time
