Motor support
15 years 3 months before #16033 by manual-mecanica
Engine Mount Published by manual-mecanica
Hi everyone. I need to replace an engine mount on a Peugeot 406. I've been told I need a press, which is a big problem for me because I don't have one. Is there any tool or other device I could use, both to remove the old one and to install the new one?
Thanks
15 years 3 months before #16039 by manual-mecanica
Manual-mechanics' response on the topic Re: Engine mount
You do not use any type of press, you take out the new support and if you buy the full new one you just change it, if you only buy the rubber, you take it to a vulcanism to put it and then install it and now
