Injection pump
15 years 3 months before #15878 by manual-mecanica
Injector pump published by Manual-Mecanica
What problem can cause the injection pump, if the vehicle goes from revolutions
15 years 3 months before #15903 by manual-mecanica
Manual-Mecanica response on the Re: Injection pump
Low probabilities that have experienced damage. At the turns, the valves are caught first, although not in all cases, a valve spring is cut out a piston on the side, I have not seen a BBA yet. Injector damaged by rpm the engine
15 years 3 months before #15914 by manual-mecanica
It is true the pump is not the one that suffers the damage when it passes from revolutions is the engine that suffers and on the occasion in new vehicles, when the computer passes the computer blocks the signal and the vehicle does not have power until you erase the code, that is to say it is in a state of emergency.
15 years 3 months before #16020 by manual-mecanica
The pump can suffer depending on the pump and that rotation raised at that time, if the line is pump if they break the weight of the advance and the pump is split, if it is a pump they break the spring and it does not work anymore, but if an engine is triggered depending on if it is pump -urb- or the engine, the pump would be the last of your plovlemas
