Golf Glaf Crystals Raise
15 years 2 months before #15777 by manual-mecanica
Crystals Golf 1997 published by Manual-Mecanica
Hello friends, I have a problem with the crystals. They only work when the alarm is activated (that is, I have to have the alarm control oppressed so that the crystals will work) but they not only go up the alrma and fall when they disagree and then do nothing.
I will appreciate any suggestion or if someone has the electrical diagrams in question. The car is of Mexican origin and the control plate is of German origin.
Thank you very much and I am awaiting your help: Dry:
15 years 1 month before #15799 by manual-mecanica
Manual-Mecanica Response On the Re: Crystals Gol Cum 1997 lifts
Is the original installation of non -alternative truth? If it is the original for what I have understood and I have seen in the part under the steering wheel and involved in between all wiring there is a black box that has two connectors and this is the sishing that fails at least in the golf that arrive in Chile
