Problems with start -up bombin
15 years 3 months before #15729 by manual-mecanica
Problems with the start-up bombin published by Manual-Mecanica
I need someone who can help me to be able to disassemble the starting bombin of my Opel Astra 2.0 Edition of the year 2003 I am arto that I timen in the workshops : Angry: : Angry:
15 years 3 months before #15739 by manual-mecanica
Manual-Mecanica Response on the Re: Problems with the Start Bombin
Excuse me, but what are you calling boot bombin ... because I think here in Mexico we don't call you like that, if you can get me out of doubt I can help you.
15 years 3 months before #15745 by manual-mecanica
The boot bombin is where the key is lodged to rush and start the vehicle. My case is that I enter the key does not let me go to the starting point (the key of the blocking point does not pass me). What I need is someone who has an idea or schemes of explodes of this PPelo to be able to make the change for micuenta. Thanks for answering my consultation
15 years 3 months before #15754 by manual-mecanica
If what you want is to repair that bomb as you call it, I recommend changing it and already repairing it is very difficult and several special tools are also not expensive so it is not worth spending so much ravia with them.
15 years 3 months before #15766 by manual-mecanica
Ooooorale ... here in Mexico we call it starting switch, I think it is written, well I agree with kikeme, but look I repair the bombin of a Renault 5 since it was stuck when turning the key, they are cheap but if you like and entertain you then it is quitther and disarm it by setting you how the pieces are going (it does not have many) That he moved from his place, some adjustment that you can approach you, maybe it only requires some lubrication, etc. etc And total but you can't fix it because you buy it, but somewhat open when trying to fix it, who removes that of Chiripaso you fix it, remember that it happened to me, well luck.
