F8Q Renault engine
18 years 3 months before #1562 by manual-mecanica
F8Q Renault Motor published by Manual-Mecanica
Friends: I have a doubt that I consider when the engine of a Renault Express disassembles with F8Q Diesel engine,
what is the light that must remain between the cylinder and the piston?
I ask this because when he found out to rectify the agonos engine, they told me that it was best to direct standard and others that only with rectifying another measure was enough, the light of the rectified remained at 0.075 approx. and that of the routing at 0.035.
Which one should I accept as valid?
Greetings
18 years 3 months before #1567 by manual-mecanica
Manual-Mecanica Answer on the RE: Motor F8Q Renault
The minimum permissible slack in that engine is 0.035 m/m that is what they have when they leave the factory.
The other measure they have given you, 0.075 m/m is the maximum permissible slack before rectifying the engine.
Whether the engine is a standard as if you rectify the shirts you have and mounts overmedy (0.50 m/m I suppose) the slack between cylinder and piston has to be 0.035 to 0.045 m/m.
The difference between one thing and another is the cost of machining and the pieces, because the mechanical resistance of the engine does not vary and the increase in displacement is almost imperceptible, so what comes out cheaper will be the most successful.
All the best.
18 years 3 months before #1573 by manual-mecanica
Thanks Megabeat_1, today leads him to rectify and he will direct it to standard
greetings
