valve gift
18 years 3 months before #1561 by manual-mecanica
Valves gift published by Manual-Mecanica
Good to all. Well, the question is how you do to turn the engine to the different points to do the adjustment. What do I have made in marine engines but it is easy since it has some holes in the steering wheel to put a bar and turn them, but in the car ???
Thanks a greeting
18 years 3 months before #1565 by manual-mecanica
Manual-Mecanica Response on the Re: Valve Gift
Hello 8 ts, that question is simpler than the mechanism of a maraca !!!
All you have to do is lift one of the motor wheels in the car, put a speed, to be possible 4 or 5th and turn the wheel you have raised.
In this way the movement will be transmitted directly to the clutch and from there to the engine.
The bad are automatic cars, in them you have to turn the engine pulling the screw on the stallion tip with a key.
All the best!
18 years 3 months before #1569 by manual-mecanica
Thanks Megabeat .. : Oops:
18 years 3 months before #1571 by manual-mecanica
You are welcome! There are repair operations that never change, another thing is the adjustment of tachy in itself, which makes them more difficult !!
Anyway, with the advances of the technique, it is easy to think that there will be some user that does such or that work.
It depends on the workshop, official services have all the necessary tools because they are provided by the firms for those who work.
In the other workshops, it depends on the budget, the less it is, the greater the ingenuity of the mechanic ...
although there are people who use the hammer even to change a lighthouse, and it should be noted that we are mechanical, not blacksmiths, everything in its fair measure.
I hope I have not bothered you about that "this question is simpler than ..." It was a joke.
All the best.
18 years 2 months before #1648 by manual-mecanica
No, it doesn't bother me at all !!! : Wink :: Wink :, A Mega greeting !!
