Nissan Micra, 2005, lacks strength.
15 years 2 months before #15540 by manual-mecanica
Look if you don't have any outdated tube (which goes to the turbo valve by ex.)
15 years 2 months before #15541 by manual-mecanica
Yes, the RPM upload well I die.
I am not a professional mechanic, I do not have a diagnostic machine.
What I have noticed "perhaps" is that when I start, something more smoke from normal and is white, but not sure that it is not normal, and just just start.
Once I start I see the cloud through the rearview and disappear, but I don't know if it is normal.
15 years 2 months before #15543 by manual-mecanica
15 years 2 months before #15544 by manual-mecanica
Hi Juaquin my name is Rosnel I'm a mechanic. Do not take your car to the workshop before making an inspection yourself, it is easy. Before I tell you what to do you have to be sure that your vehicle has the following characteristics.
4 -cylinder engine online, front traction, 1240 cc, 4 valves per cylinder, double camshaft, indirect multipuntos, 5 speeds, gasoline fuel.
If your car has those characteristics you must discard the possibilities of possible failures before buying spare parts, spending money and wasting valuable time.
When the cars are electronic the mechanics are confused because they are new technology but finally it is only care and malice to solve the failures.
When a vehicle starts but does not raise power you have a problem in the spark plug coils. You realize because the smell of gasoline comes out of the mufla when you accelerate it.
With the car started, remove the chupon one of the spark plugs, you take it out and put it again with a pliers that have an insulator so that the current does not pull. If you notice that the engine is lowered or disturbed that indicates that the coil is fine, but if you do nothing you have the bad coil. you buy it and change it. Anything you write to me
15 years 2 months before #15547 by manual-mecanica
Hello, thanks for your answer, but my car has a 1.5 diesel engine, not a gasoline.
On the other hand, the workshop to which I take it is the Nissan house, the problem is that they charge a lot, but they do not tell you exactly what it has to take it to a neighborhood mechanic with the piece of scratch or bought online, to save money. But if it is not more or less what can happen to you or the piece I have to buy ......... I will have to pay the € 500 ($ 640) that you ask for the house.
