Water in transmission oil. Xtrail
15 years 4 months before #15211 by manual-mecanica
Manual-Mecanica response on the Re: Water in transmission oil. Xtrail
This also goes for those who ask the questions, because if they do not thick the characteristics of their vehicle one assumes things that can lead to a wrong diagnosis, already misunderstandings, greetings and are absolute do not bother, errors are made due to lack of information here is to help in the best possible way.
15 years 4 months before #15246 by manual-mecanica
I agree, you have to read the question well the Lambda sensor has nothing to do so between or not between speed, now the mechanic says that water enters the box, ok. And you say because you have to check it yourself and see that water has effectively messed to the transmission liquid, do not completely find out what the mechanics tell them. Now, the boxes are sealed but it comes out liquid because it does not enter, look at him, I think what you should do is the change of liquid and filter to your box (what some call you tuning), you must do every certain quilomethex Czech your maintenance manual.
15 years 4 months before #15266 by manual-mecanica
PS well if it is possible that between aqgua in the transmission and there are only 2 ways that this occurs if it reaches the breath it is possible that it absorbs some water although it would need to be flooded for a long time for this to happen and the other is when the internal serpentin of the cooling radiator suffers an internal rupture and mixes the radiator antifreeze with the transmission oil in which case it will be burned repair Well on the other hand I need a little more information to guide you with respect to your main problem, what looks like your transmission oil, what smell do you perceive, have you checked the level? And what model is your Xtrail see you later
15 years 4 months before #15267 by manual-mecanica
I forgot to give you another fact, the speed sensor is used by the computer to define the change strategy, when it fails will only have erroneous or null changes but always advance
15 years 4 months before #15295 by manual-mecanica
If your problem is water in the transmission oil that your CK the water radiator since 2 transfront oil sleeves are. The radiator has a brown that is broken. They sell universal oil cooler adapt one. I hope the sewing serves you : Laugh:
