Difference between starts with 9 and 11 teeth
15 years 3 months before #14967 by manual-mecanica
Difference between starts with 9 and 11 teeth published by Manual-Mecanica
Hello! I need to know the difference between the two starts (9 and 11 teeth). Which is more convenient for a 1.9 Podgeot Diesel engine?
15 years 3 months before #14984 by manual-mecanica
Manual-Mecanica response on the Re: difference between starts with 9 and 11 teeth
It depends if you bring the 11 eleven and if you bring the 9 nine, there is not much more the one again in the 11th and viseverse, this depends on the manufacturer but put the one that breaks but lasts very little if it works for you, since the step is not the same of the vokante, in the without words you cannot put a 11 if it is nine-
15 years 3 months before #14991 by manual-mecanica
The crown tooth distance is not the same as a 9 teeth pineapple to one from 11, if you don't put the one that touches it when you start it scratches the pinion in the crown.
15 years 2 months before #15011 by manual-mecanica
Thanks for your answer!
15 years 2 months before #15012 by manual-mecanica
Thank you for your answer, the topic is that I do not know what starts it carries ... No one can tell me exactly which one that is going. Is there any table or a method that tells me according to the crown that the engine has?
