Socorrooooooooo Crysler Neon with Averia
15 years 3 months before #14949 by manual-mecanica
Socorrooooooooo Crysler Neon with Averia published by Manual-Mecanica
Hello, I bought a Crysler Neon and it turns out that the car is with fault (it gets oil in water) changes the joint joint and in this matter is already areglao but it does not go more than 120 km and when I put the air ac is heated a lot is of gasoline 2000 cm 134 horse please some that can support me a lot thanks .............
15 years 3 months before #14973 by manual-mecanica
Manual-Mecanica Answer on the Re: Socorroooooooooo Crysler Neon with Averia
If this bleeding properly did not devote Tenpeat problems, but you get a question to advance faster, you rectified the cylinder head or just changed the packaging.
15 years 2 months before #15092 by manual-mecanica
That such a friend
tells me that he heats up when he travels a certain kms and with the ac ignition.
I recommend you check that the 2 radiator fans properly work when the AC, that the radiator is not covered or dirty, water pump or thermostat, to check these lasts
with care not to burn you touches the two hoses of the radiator, if one is cold and another hot you bring water circulation problems, if the height persists, you can
take the posivility of the culata burst
