Electric
15 years 3 weeks before #14825 by manual-mecanica
Electric published by Manual-Mecanica
Hello everyone and thanks for taking the time to help, my problem is as follows: the rear right window fin did not want to open, it is a Mexican Grand Voyager '98, I disarmed the controls, it appears to be fine, but it does not reach the engine of the fin and in the fuse box that is under the board there is no one that tells me that it belongs to that window of the window
15 years 3 weeks before #14857 by manual-mecanica
Manual-Mecanica Response on the Re: Electric
Have you looked at continuity in the cables that go from the door to the module of the windows?
Because if all the windows work except that, the first thing is to feed the engine externally to see if the glass goes up and down and the second is that in case it works, look at the cables and masses in case something had been released.
All the best.
15 years 3 weeks before #14874 by manual-mecanica
Ok. I will review how you comment and post results thank you very much for your contribution
15 years 2 weeks before #15091 by manual-mecanica
Friend generally on the side of the driver there is a control with trolmer other crystals if so check if voltage comes out for that glass I dare.
15 years 1 week before #15144 by manual-mecanica
I had the same problem with defernce that my car is a pontiac but it also failed and there was continuity and everything disarmed the swicht and washed very well.
