Information about Nissan Xtrail
15 years 3 months before #14558 by manual-mecanica
Information about Nissan Xtrail published by Manual-Mecanica
Greetings
could help me. I have an Xtrail 06, when the full fuel tank filled. The level indicator in the main panel does not mark the maximum. Caul will be the problem. Someone who has the Spanish workshop manual of the Xtrail gasoline that can fasilitar
15 years 3 months before #14561 by manual-mecanica
Manual-Mecanica Answer on the Re: Information about Nissan Xtrail
In principle it can be something as simple as the aforerator (float that goes within the deposit responsible for measuring the fuel level), is damaged or stuck.
Sometimes the cursor does not make good contact and causes the clock needle not to mark well or go up and down.
Other times the and does not rise to the top, even if it is full, causing the clock to miss.
All the best.
15 years 3 months before #14566 by manual-mecanica
It can also be that the score comb this spends on its last lines or not to contact, the other that if any repair is realized in the last time in the Ayan pump folded the float leg when removed.
15 years 3 months before #14568 by manual-mecanica
good night.
I think it would be good for you to check the instrument of the board a sensilla test that you can do is send the cable that comes from the sensor to the ground tank so that the coil of the instrument is exite the maximum by some moments as the problem comes to full the problem is in the tank.
luck...
15 years 3 months before #14581 by manual-mecanica
Thank you very much for the comments, I will verify the indicated
