Volkswagen Gol 93 problem
14 years 11 months before #14486 by manual-mecanica
Volkswagen Gol 93 problem published by Manual-Mecanica
Hello, I have a problem with the masses of the rear wheels of my goal, after making a few kilometers loosen, the rulee are ok, the threads are ok, it has no way of loosening but the issue is that they do it. Buano, any information that I can give me I thank you
14 years 11 months before #14504 by manual-mecanica
Manual-Mecanica Answer on the Re: Problem with Volkswagen Gol 93
Hello friend, if you have autofrenantes, put the new nuts and if it is with a key, fix that the cubets of the rulee are thoroughly in the masses, luck and greetings.
14 years 11 months before #14518 by manual-mecanica
These nuts do not have insurance or back or go, you have to squeeze them very strong with the help of a tube, but not much not to burst the bearings, what Ise was to put some lock threads so that they do not release test you do not lose anything.
14 years 11 months before #14522 by manual-mecanica
Hello, thanks for the answers, but I tell you that those that loosen are the traceras wheels, they go with a key, and the rulee are capped, and as mentioned above, the threads of the axis and that of the nuts are fine : HUH: : Dry:
14 years 10 months before #15255 by manual-mecanica
Those of front well say that butt with a bar, but behind you do not even think that they are conical bearings that have to be adjusted and they cannot be stopped.
