I have a problem with the brakes of a Santana
15 years 5 months before #14456 by manual-mecanica
If I ask for three times the pedal slows me back and if I only give it once it does not stop me from behind
15 years 5 months before #14473 by manual-mecanica
Manual-mechanics' response on the topic Re: I have a problem with the brakes on a Santana
Check that there's no air in the brake system and that there are no leaks in the system; I think it's just coming from there.
15 years 5 months before #14487 by manual-mecanica
Check if it has braking balance valves; perhaps it has problems.
15 years 5 months before #14524 by manual-mecanica
Thank you very much, colleagues.
15 years 5 months before #14526 by manual-mecanica
Did you change the brake shoes?
Did you adjust the rear brakes?
Do the pads move when you pedal? (front brakes without removing the tires)
Did you check if the valve is adjustable?
Changing the brake shoes, resurfacing the drums, and seating the shoes on the drum with a machine and proper assembly guarantees the solution.
