WV DERBY 1.8L Mod. 95 does not turn on
15 years 5 months before #14425 by manual-mecanica
WV DERBY 1.8L Mod. 95 does not light published by Manual-Mecanica
Hello everyone, I have a VW Derby 95 The problem is that when changing the water pump (it was had to remove the pulley that moves the distributor) no longer wanted to pender has no spark spark, if some suggestion or experience just as you want to share them. Thank you.
15 years 5 months before #14442 by manual-mecanica
Manual-Mecanica Response on the Re: WV Derby 1.8L Mod. 95 does not turn on
hello.
You could verify by disassembling the distributor and you turn it manually, with all the connected signals and even a carcaza cable to the engine with this you will discard any transmission problem to the distributor. The most likely it is that it is the ignition module.
Informen ......
Suerter
15 years 5 months before #14467 by manual-mecanica
Check out the tuning, I think that is the whole problem, the motor flywheel marks to be in OT, and the camshaft pulley has a point marked by its tracera face that point must be online with the edge of the butt, then chisronisas the distributor so that it jumps to 1 and then only regulas the ABANCE.
15 years 5 months before #14500 by manual-mecanica
Hello friends, I thank you for your contributions, again withdraw the time band and the points were reverified on the Sigual and camshaft and they are corctus, as I tell you the hall or ignition sensor, again, take off the distributor The same, what we notice is that the distributor does not fall well is a bit raised as it does not feel good in the engine wedge, but if the rotor may turn through the rgrane that I rotate it and not because of the wedge today I will disarm the distribution to see if it is having well in the wedge or not perhaps this is the problem or the sensor that I buy this bad is also new. Taking advantage of the fact that time has already improved (Hurricane Alex spent) greetings.
15 years 4 months before #15327 by manual-mecanica
: blush: Hello everyone I tell you that the derby still does not turn on, the whole distributor and the mechanic are changed. brand.Saludos.
