Water in the oil I do?
15 years 5 months before #14414 by manual-mecanica
Water in the oil I do? Posted by manual-mecanica
Young to my Wagon Ford Windstar 1996 I have detected water in the oil, this after I broke a cooling hose and the engine is heated a bit, what does it have to do in these cases?
Surely are the heads of the heads that occurred right?
any recommendation ??
Thank you, I thank you for your
thank's contribution to Lot
Animo;)
15 years 5 months before #14423 by manual-mecanica
Manual-Mecanica response on the re: water in the oil I do?
This is what you say if the oil is made on the water or the setback you will have to change the cylinder heads.
15 years 5 months before #14443 by manual-mecanica
hello. I agree with the previous cause of the fault; But I recommend that you verify the fullness of the butt adjustment face, most likely it has suffered deformation, you can rectify the adjustment zone and advise if your engine has packaging scales. Informen ..
luck ... luck ...
15 years 5 months before #14445 by manual-mecanica
Thanks for the subjects, it is definitely true what you comment that I must rectify the butt in case they suffered distortion, I will keep you informed
thanks.
cheer up: Laugh:
15 years 5 months before #14468 by manual-mecanica
Hojo Myky 72 If you are doing the paste yourself, I recommend marking you with a liquid concealer or some pencil that marks iron, the position in which you take out the chain, so that you have no problems when assembling, mark the chain with the piñon where it is uvic, that is, a tooth of the chain and just the position where it fits into the pulley, which will be easier.
