Fiat Stilo Bizonal Climatizer
15 years 1 month before #14392 by manual-mecanica
Fiat Stilo Stilo Bizonal Climatizer Published by Manual-Mecanica
Estimated MDM friends, my question is: I have a 3P Fiat Stilo with Bizona air conditioner and it takes a time that comes out very little air flow, the antipolen filter changed for a new one but the problem persists, I do not know if it will be due to the switchboard or some relay that is failing. Any suggestion? Thank you very much in advance.
15 years 1 month before #14421 by manual-mecanica
Manual-Mecanica Answer on the Re: Bizonal Climatizer Fiat Stilo
Czech first than the air is loaded, that of the air conditioning
15 years 1 month before #14432 by manual-mecanica
I think it should be loaded, this would be the second summer since the last time I happened to him and last summer the same thing happened to him, so I have to think that the problem will not be in the lobby of the air conditioner.
15 years 1 month before #14471 by manual-mecanica
You may have a escape in the system, it is the easiest and fastest, also when I spend last summer, then take off something or something something? Well luck and warn, the first step is what I told you before disarming anything.
15 years 1 month before #14520 by manual-mecanica
Aver, if you put hot air, it comes out in quantity ?? And if you put the cold no?
