Mercedesml320 Air Conditioning Problem
15 years 4 months before #14295 by manual-mecanica
Mercedesml320 Air Conditioning Problem published by Manual-Mecanica
The compressor turns off the refrigerant load and is complete that someone could be happening that can be a sensor I appreciate help
15 years 4 months before #14297 by manual-mecanica
Manual-Mecanica Response on the Re: Mercedesml320 Air Conditioning Problem
Hi, look that has a security valve the high pipe may not be turning on the condenser interioor or electro
15 years 4 months before #14298 by manual-mecanica
It is sure that the capillary duct tapo and that an excess of pressure generated by the compressor is activating the high pressure sensor and that is why the compressor is disconnected shortly after being activated
