Rover 200
15 years 4 months before #14285 by manual-mecanica
Rover 200 posted by Manual-Mecanica
Good morning my problem is the following when the vehicle starts, it stays in the sole clip, the cargo battery, Arramque Okyy engine is demoma the hydraulic belt is if the arramque performs.
I continue with the problem I thank you for your orientation
15 years 4 months before #14314 by manual-mecanica
Manual-Mecanica Response on the Re: Rover 200
I did not understand you well without the hydraulic strap, the starting works?, if the answer is whether the start is desoliated and with all the load it has not enough strength, if the answer is no, there will be the contact of the car and with a screwdriver you will have to start between the two terminal You can see with a tester or a trial lamp if the sheet of sheet metal arrives at the test test and let us know.
