Problems with my water pump
15 years 4 months before #14278 by manual-mecanica
Problems with my water pump published by Manual-Mecanica
Salu2 ... I have a problem with the bomb of my tsuru´92 since from Ade it began to have a filtration from a hole that has on the bottom ... My question is Can you seal this hole or has a special function? Is it necessary to replace the pump?
15 years 4 months before #14290 by manual-mecanica
Manual-Mecanica response on the Re: problems with my water pump
Give me more details, it is important for a diagnosis
15 years 4 months before #14291 by manual-mecanica
Hello friend, that hole as you say is a download that the bomb has, when it begins to lose because of the no choice but to change it, greetings. :)
15 years 4 months before #14303 by manual-mecanica
Good night.
Regarding the fault that has been presented to you what I can tell you is that this hole that you name is a witness hole that carries all the driving water and centrifugal type pumps.
The objective of this hole is to alert that the mechanical water seal of this pump has failed and you run the risk that the pump bearing contaminates you and can cause a much more serious failure in the distribution system.
The recommendation that I can do is that there is the possibility of changing that seal, as long as the pump body is of molten iron alloy material since the clearing must do with a press. Those of aluminum alloy is likely to be destroyed, in that case it is advisable to change the complete pump.
15 years 4 months before #14312 by manual-mecanica
Thank you so much! I could not answer before since I had problems with my PC, my pump is aluminum and I will replace your recommendation.
