centralized closure, bomab blockade
15 years 4 months before #14255 by manual-mecanica
centralized closure, bomab block published by manual-mecanica
WUENAS I have the central lock pump (centralized lock) that makes a lot of noise and does not work properly, or open or close the doors of the
vehicle car: Pole of 98
Shop.vws.me.uk/ekmps/shops/stevensvw/images/%5b1%5d%2840%29.jpg
I have a doubt .. With replacing the boma would be enough?
I have noticed that it carries a connected plastic tube, in the photo you can see, the white plate would be, there goes the tube ..
15 years 4 months before #14261 by manual-mecanica
Manual-Mecanica response on the Re: central locking, bomab block
Change only the piece you show in the photo, the tube that enters this if it is in good condition does not re -remember it that when installing, there are no leaks
15 years 4 months before #14267 by manual-mecanica
Could it be that the noise of the pump is because there is any leakage through the tube? Or is it directly the bomb?
15 years 4 months before #14274 by manual-mecanica
That depends on the noise you feel if the noise is like whistle then is a leakage or succative leak, if it is like spreading with stones then it is the pump itself hahaha, or if it has any strange noise, that is not air
15 years 4 months before #14279 by manual-mecanica
