Help with a A2 jetta
15 years 6 months before #14216 by manual-mecanica
Help with an A2 jetta published by Manual-Mecanica
Well my car was getting smoke, but it worked as pearls and to solve the smoke I put the normal:
-He cleaned spark plugs (since they are new)
-quite the carburetor and I gave a cleaner to all the carburetor
-Filtros changed
and when I decided to try my car I left super slow to egg advances and keeps getting smoke and it is spending a lot of gas. Gas, take off the spark plugs and put others and the car that slowly cannot climb the climbs: Angry: because it is super slow.
I hope and can help me solve my problem and can help me from now thanks to those who help me.
15 years 6 months before #14229 by manual-mecanica
Manual-Mecanica Response on the Re: Help with an A2 jetta
You bit the carburetor, you wanted you not to be as it was and you changed the position gum, or you spoiled the pique pump, I think it is only carburetor and nothing else.
15 years 6 months before #14231 by manual-mecanica
Do not tell me that: Laugh: : Laugh: :( I did the normal what normally did everything take away the carburetor to be able to clean it well and the car was well pull of pearls, so I don't know? Only with what I did to the car I am like this gacho and slowly feels good the car and the accelerator pedal.
15 years 6 months before #14248 by manual-mecanica
You want this bad piola or admission butterfly, Check it again because it smells like the corduroy, or the level of the float
15 years 6 months before #14260 by manual-mecanica
Good afternoon
according to my experience, it is important to know if you changed something to the carburetor, because when they already have the injector, ahuja and the seat and many other parts of the same they have wear but they are twin and that makes your car fail and when you clean them and put the same piece again causes goals of air or gasoline, what I suggest is that you change the replacement and torch You have a lot of care for the assembly, waiting for these humble advice to send you a cordial greeting. Wilbert
