The engine is blocked
15 years 4 months before #14208 by manual-mecanica
The engine is blocked by manual-mecanica
Hello everyone, I have a problem with my engine, I was trying to start my solediesel engine and after turning perfectly well, that was blocked that was the Saturday and today I have tried to turn manually and I can turn it to the opposite direction that makes it turn the starter engine and turn perfectly until it comes to block, while I turn something we hear something strange in the injection pump, so I think the injection pump has something to do. You know some that can happen to him or if someone has happened to him. (I hope opinions please)
15 years 4 months before #14223 by manual-mecanica
Manual-Mecanica response on the Re: the engine is blocked
So you say the engine is struck because it is out of point and caught the valves, this is why you say, if you have noise in the pump it is that it is bad the bearing or disassembles something and jump your teeth, but if your vehicle is equipped with oil depressant at the exit of the cracking cams because the exentric one can be crooked and it is traced, this happens to the renaults,
