Carburetor problems
15 years 4 months before #14094 by manual-mecanica
Carburetor problems published by Manual-Mecanica
Hello good afternoon I am new here and I pre -defect is how I can serve the caribbean of a Caribbean vw 81 pk I have problems with it, and I would like the service I myself thank you very much : Cheer:
15 years 4 months before #14119 by manual-mecanica
Manual-Mecanica Response on the Re: Problems with the carburetor
You have to disassemble it, clean it checked the gum level of the float and check the needle once this is done, mount and carbon.
15 years 4 months before #14181 by manual-mecanica
Look, do not be afraid to disassemble it and gradually disarm it by setting the pieces as ban, see them fix them in the spases because they have very small holes you also have to clean them and uncover them, I recommend that you also change the carburetor joint, and another thing I go beyond, I recommend that you wash your gas tank since over time it is accumulating water by the condensation in addition to the impurities that it brings in addition to the impure. Gasoline, this water and impurities sometimes reach the carburetor and that is when the ship fails, well I did it with a renault 5 tl 78 and I luxury. Do not forget to carbure it or that your trust mechanic will carbure it and there are Pal Chesco.
