Help with fan
15 years 6 months before #13966 by manual-mecanica
Help with fan published by Manual-Mecanica
Hello everyone, I have the next problem the fan of my Peugeot 206 stopped working from one moment to another I checked all the fuses and are all ok. According to listening there is a resistance to the electro -ventilator that say it is on the side of the co -pilot. Some can help me please
greetings
15 years 6 months before #13978 by manual-mecanica
Manual-Mecanica Response on the Re: Help with fan
Siya Czechs the fuses and everything is fine you just have to change the ralaig that is under the chassis or one side of the radiator or below the battery but Eye first tests the bentilator to discard that point
15 years 6 months before #14019 by manual-mecanica
Thank you
, do you mean the fan of the air inside the vehicle?
since it does not work in anyone of the 4 positions (1-2-3-4)
greetings
15 years 6 months before #14048 by manual-mecanica
If these resistances effectively fail, you will have to remove the glove compartment, go to bed on the car of the car watching up you will see a duct where the car aspires the ventilation for the Motor Blower and put the gate on Airwe recirculated if you will not see the resistance when the locisses are toured asia the left do you pull it and come with the wiring
. It would be to change terminals or weld cables direct to the terminals greetings and luck: Woohoo:
15 years 6 months before #14056 by manual-mecanica
Good, in 306 HDI has a box of relays just above the electro -ventilator, I had problems and I could go crazy following the failure of the relay and found it. It is to disassemble the calendra and there is.
If you want you can check if the 206 has just above the fan the secret box looking through the Morro grid.
