The Ford Couer temperature raises 1.6 L
15 years 4 months before #14254 by manual-mecanica
Manual-Mecanica response on the Re: the Ford Couer temperature 1.6 L rises 1.6 L
As they say, check at the pressure of the cooling system. It can be something as simple but very common as the refrigerant tank cap does not work. This plug opens when the pressure of 20.3 psi reaches. When it is no longer useful, it opens at lower pressure and therefore the water of the system boils. Some caps that are sold do not even indicate what pressure they open. You can try the cap, connecting a pressure gauge where the refrigerant enters the tank and where air is injected using a simple air pump (the bicycle). Go until pressure the cap opens and starts to let out.
15 years 4 months before #14259 by manual-mecanica
Good afternoon
friend
after the successful comments of the classmates I give you my humble opinion, for me it is your head is that how I already suffered heating the head of the head of the head already burn or to do the same one, what I recommend is that they brush your head and change the joint and ready I know that you are going to invest a little but already spent more and it has not remained that it is the worst. It was. Greetings Wilbert
