The Ford Couer temperature raises 1.6 L
15 years 4 months before #13919 by manual-mecanica
The Ford Couer temperature 1.6 l published by Manual-Mecanica
I have a problem with the Ford Couer 1.6 L, the temperature rises too much, the thermostat, the radiator, the water pump, the range of the radiator everything in short, but still rise the temperature, but I hope someone can help me, thank you, thank you
15 years 4 months before #13939 by manual-mecanica
Manual-Mecanica response on the Re: the Ford Couer temperature 1.6 L rises 1.6 L
Do you have thermos fan or electroventillator?, is it activated? The vehicle is really heated or only indicates the clock that does it, check the oil that is not emulsifier, that the water is not oiled and that there is no compression in the refrigeration system if any of these tests gives you positive you have cylinder head problems, if you have two butts like some Ford you just change the packing and rectificed the one that is bad, answer to help you better.
15 years 4 months before #13942 by manual-mecanica
The temperature rises in the engine and on the scoreboard, the oil is clean, it has no water. The fan is electric and works well.
15 years 4 months before #13969 by manual-mecanica
And the bulb works to the right tennis?
15 years 4 months before #13976 by manual-mecanica
Look what the colleague says has reason to need to check the preservation of the cooling system of your engine and check if the pressure or not another way of chekar puts the hand in the mofler and check if it releases baor and if it is so the joints of the butts are already broken only replace them and ready
