Start and operation problem ROVER 220SD
15 years 6 months before #13761 by manual-mecanica
Start and operation problem ROVER 220SD Published by Manual-Mecanica
Good afternoon.
I am new here, I have the car 2 weeks already in the workshop and they do not know what it is !! I tell you the problem having if someone can help me ...
with the car in cold, you give the key and start the first, without problems and without stepping on the accelerator, but nothing else has started is as if the car is drowning and stops ... you start it again and the same thing happens ... now if you start it and step on it the accelerator keeping it 1-2 minutes to 2000 laps, loose the accelerator and it is no longer stopped.
The mechanic has looked at me if there are air intakes from the déposito to the injection pump, the diesel filter, has proven pump pressure and is all good ... does anyone have an idea of ​​what it can be?
Thank you.
Greetings,
15 years 6 months before #13767 by manual-mecanica
Manual-Mecanica Response on the Re: Start and operation problem ROVER 220SD
Hello, it is possible that the injection baomba is too late. Tell your mechanic to make the basic adjustment with the diagnosis, it should be over +3.5º.This can pass after changing the straps or by the bombing of the pump strap.
