transmission oil change to an escape 2005
15 years 7 months before #13585 by manual-mecanica
transmission oil change to a 2005 escape published by manual-mecanica
The exhaust breaks with front transmission, I don't know what I have to know to change the oil and filter and some advice to make a setting tell me that this engine only changed the spark plugs. Since thank you very much
15 years 7 months before #13600 by manual-mecanica
Manual-Mecanica Response on the Re: change of transmission oil to an escape 2005
which filter is the box automatic?
15 years 6 months before #13784 by manual-mecanica
Good evening, I look at I just made the tuning of my truck a Nissan Quest 96, I speak of the transmission box, a bit that is automatic, I will tell you that if they carry a filter, I change the filter and take 7 liters of fluid for automatic transmission dexon III mercon, first you have to drain the entire liquid stop having a screw Used and you put the new, perfectly well the lid that you removed observing that you do not have bounces since that indicates an important wear, I recommend that you also change the lid joint, you put everything in its place and make the new liquid you usually take it through the hole of the ball, when you already have the required one on your engine and make all the changes pr 1 Czech the level, I hope my advice serves you
