Start problems of the Ford Ranger 3.0 Pow
15 years 5 months before #13486 by manual-mecanica
Hello.
I have problems with the positive battery cable that goes to the starter engine. When I try to start this, it is short, it heats up and melts a large fuse in the line. The donkey was reviewed outside and has nothing. You can help me. Thank you so much.
15 years 5 months before #13501 by manual-mecanica
You already checked the march that is not locked or stunned or with the bearings or very spent buses and is dragging causing the short or even the automatic march
15 years 5 months before #13509 by manual-mecanica
It is rare what you say, if when you try it outside it works correctly the start of the positive cable of the battery that goes to the start it should be making mass somewhere test with another cable to see what happens renlass that positive and test.
