Help 3
15 years 5 months before #13395 by manual-mecanica
Help 3 published by Manual-Mecanica
good
portal 1 I have a Dodge Neon 95 and at times comes a very recurrent failure
. Obre accelerates
3 caavan does not take it does not inject and with direct gasoline I would not
appreciate their help because I am just beginning in my own workshop and I do not want to fail gacias to all: Woohoo:
15 years 5 months before #13408 by manual-mecanica
Manual-Mecanica Answer on the Re: Help 3
Av here you have several details and many things to review yet, because the information you give is not very good.
First: Dodge Neon, erase all the failures of the computer's memory and you have failed, when the Czech Aga specifically what code gives you, and tell us if it stops the vehicle or not, that raw gasoline may be lack of air by IAC in poor condition or dirty, or the TP does not fall as it has to be for a damaged track.
The Atos goes out or accelerates, if you do both things, it could also be an IAC problem that does not regulate correctly but you do not tell us if it is injected or carbaded, but you could do a test by taking out your thermostat if everything goes well buy the temperature sensor.
Third, caravan check if you have a spark first if it injects fuel, if there is no spark they can be several different problems and only no fuel is problem with the pump or relay of it or with the computer blokeo. Choca first and let us know,
luck with your workshop, just have it without fear.
15 years 5 months before #13427 by manual-mecanica
Thank you very much for everything about the caravan if it was the gasoline bomb and continue checking the atos is of electronic injection and continues with the same lost failure of power and turns off with the neon if you continue to apply and the scanie gives me code of the ¨Egr, IC, module of the alternator or generator and the fan of the fan, but I will remain advance day be the best of days for you thanks.
