malfunction
15 years 5 months before #13388 by manual-mecanica
Mal function published by Manual-Mecanica
hello!!!! I have a problem with a Pontiac Sunbird 92, what happens is that it turns off when brake and then turn on again, change the DIS module and a coil, I do not know what the revulutions can be almost up to 2000/Hy then go down to normal, and when they go out they fall to less than 500/h.
15 years 5 months before #13405 by manual-mecanica
Manual-Mecanica Response on the Re: Mal functioning
If it only happens to you when braking can be an electrical problem, check this you have normally walk and disconnect the fuse of the brake lights, and step on it if it is not for it is an electrical problem, but you have the test first and let me know, I tube a problem like this on a kia abella and delay as 1 month in giving the corduroy warn and explain how to continue.
15 years 5 months before #13570 by manual-mecanica
Thank you carnal, I'm going to do it even if I don't know what I pass !!!! "! :)
15 years 5 months before #13574 by manual-mecanica
Look I recommend that you clean the idle valve, remove it and clean it with that spray to clean acceleration body and then lubrication with oil, see how it follows.
