Failure in Tsurullll
15 years 7 months before #13386 by manual-mecanica
Failure in Tsurulll posted by Manual-Mecanica
Help me get the fault from my tsuru since I do not have a scanner, it only drowns and does not start, change the distributor because they stole it and now makes this fault I changed the computer but it is still equal to beforehand Ngracias
15 years 7 months before #13392 by manual-mecanica
Manual-Mecanica Answer on the Re: Failure in Tsurullll
Hello my company,
I am Alonso Cruz de Huatabampo Sonora Mexico What we need is more details of the failures because it may not be putting the distributor on time another that does not have the coil spark
but checks what the coil is spark but take care that you do not give you a useful electrical discharge. Is it good to make the engine on time
how to put the engine on time?
1.-Pon the piston #1 above you have to
hear
that
blows 2 . You publish it and we'll see
15 years 7 months before #13466 by manual-mecanica
Thanks Alonso and check the time and the current and everything works as a hect if I disconnect the feeding of the pump to slab injectors with many problems starts logical when the gas is finished in the ratist 1 minute approx the problem is turned off is that the entry of gas to the piston is not controlled to the piston already changed until the module because with a Scaner they told me that it was and the truth is still the same and I have the truth and the truth is the truth. While I hope to help someone I promise you to look for nut snow. Thanks and we are pending
15 years 7 months before #13472 by manual-mecanica
Hello, I am an asknse you
already reviewed the pressure regulator of the DISSES INJECTOR SYSTEM that you drown you change your injectors is that you do not explain to you, it is that I do not understand forgive you
15 years 7 months before #13493 by manual-mecanica
That Honda Alonso already checked that and the injectors already changed them, I tell you the whole problem I stole my car and half devalued it recovered it but the distributor was missing and the battery that as soon as the engine to make it to walk I got a distributor and a battery from that when handling it just walking only, so much so that even by the multiple of exhaust you pull gas and I do not start On time, check injectors etc. They put a Scaner and told me that the module or computer was damaged and that with changing it would work properly, I got another module and put it but still making the same failure. I hope that with this explanation the failure panorama will clarify a little more. Thanks in advance and make good day
