MECHANICAL FAILURE IN A GRANDE Cherokee 98 American
15 years 5 months before #13487 by manual-mecanica
Friend in my workshop we had a similar problem, the gasoline pump was replaced and the explosions disappeared, by measuring the pump pressure on us 55 psi but it did not work correctly by having to feed the circuit
15 years 5 months before #13499 by manual-mecanica
Thank you very much for the information for the pressure on the day that was Czech only gave 50 psi, but I also believe that the pressure regulator is what allows 50 psi pressure but we are going to check thanks.
