Gol 98 with temperature problems .....
15 years 5 months before #13324 by manual-mecanica
Gol 98 with temperature problems ..... published by manual-mecanica
Well guys, the theme is the following I have an ab9 goal which does not lower the temperature I commit them thermostat new 87º electro bulb 90º Anticorrosive water all my life the pump is fine with use but well the electro works but the car rises to 110º and does not lower even to sticks spits all the water.
TESTEE CYLINDER X CYLINDER AND THE BOARD IS OK XQ DOES NOT BUBBLE TO THE IDEA ???
15 years 5 months before #13329 by manual-mecanica
Manual-Mecanica response on the Re: Gol 98 with temperature problems .....
Did you already check that the refrigerant deposit plug is in good condition? Possibly escaping some pressure on there and does not let the fan among the fan.
It also checks if the fan system is in good condition.
15 years 5 months before #13330 by manual-mecanica
If the plug is fine and the electro starts from one but the same goes up. I play and take out the cylinder head and check the Board No Reniego but thank you very much the same
15 years 5 months before #13331 by manual-mecanica
probe the cooling system to review if there is any obstruction is also a good idea
15 years 5 months before #13342 by manual-mecanica
Hello friend, you also check the water pump and the pulley that the command, it is mounted with vulcanized and when skirting patina is broken and the pump does not throw enough flow, but it is likely that the combustion gases are passed to the cooling system through the joint of the cylinders, luck and tell us as it went, greetings.
