Acesoraminto
15 years 5 months before #13315 by manual-mecanica
Acesoramint published by Manual-Mecanica
Hello, I have a problmema with a Wolvagen Polo I did EMBRUGU what happens now is that I do not check all the fuses and the wiring the only thing that I have dua is that I tine a sensor a sensor goes back in the cja of changes I also did the test of connecting it when I arm it I made it walk in second Andubo the engine and then I do not start more epe
15 years 5 months before #13350 by manual-mecanica
Manual-Mecanica Response on the Re: Acesoraminto
Czech that the lands are well placed and clean, then check that sensor that you say because if it is a magnet captor you will not have a spark, and you will repair it, if it is the speed sensor then you would not have problems at the start, the other thing that is important so that we advise you is that you tell us if the vehicle does not part due to lack of spark Computer Blokeo problem, but first the lack of spark or fuel first.
