It turns off with the Acend air.
18 years 6 months before #1330 by manual-mecanica
It turns off with the Acend air. Posted by manual-mecanica
I have a Pointer99 and when the air turns on the car, they already made tuning and they could not tell me what the problem is, it goes out mostly when I start to stop or stop simply accelerated and when I stop treading
18 years 5 months before #1361 by manual-mecanica
Manual-mecanica response on the Re: It turns off with the AGOND air.
The problem you have is given because there is no communication between the button that acts the AA compressor and the engine injection switchboard.
This is easily noticed that when you put the air conditioning the engine accelerates a bit. In gasoline carburation engines, there is a lung driven by a solenoid valve and the engine vacuum that pulls the accelerator cable so that the regime rises and does not heat.
The injection switchboard provides an "extra" amount of fuel when the air conditioning is on to prevent the engine from being easily covered in deceleration cuts, the gasoline supply is reestabbed from 1500 rpm instead of the normal 1000 rpm.
The failure must be in the button itself, in the wiring or in some relay, if you can take it to an electrician who looks at you.
I hope I have helped you.
