Help with Hyundai Atos 2000 gives pulls
15 years 7 months before #13196 by manual-mecanica
Help with Hyundai Atos 2000 gives pulls published by Manual-Mecanica
Hello everyone, I hope you make me a hand with this breakdown is an Atos Prime 2000 scheme when it heats up when you give some small pulls and when it is thoroughly assault it rattle [IMG/] they have already looked at the fuel pump I change the refrigerant sensor and nothing continues to fail is only when this car is heated this car does not have a fault notice of fault or probe Lambda if someone can help me.
15 years 7 months before #13228 by manual-mecanica
Manual-Mecanica Answer on the Re: Help with Hyundai Atos 2000 DI Tirones
Try it by drawing the thermostat see what happens.
15 years 7 months before #13262 by manual-mecanica
Hello everyone repaired the breakdown was the semi of the crankshaft so they already know it ... he defeats everyone. :)
2 years 7 months before #54427 by manual-mecanica
Thanks Dareko! I have the same problem and I want to change the crankshaft sensor myself. I am clear how to do it and synchronize, but I don't know how to block the crankshaft pulley to remove the screw. Some say that putting a screwdriver between the wheel tooth and the starter engine. But I am not sure.
I thank you for sharing the solution to your problem. Thank you so much!
2 years 5 months before #54436 By manual-workshop
Manual-workshop response on the Re: Help with Hyundai Atos 2000 gives pulls
The normal thing is what the compis indicates, block the pulley with a large screwdriver while loosening the screw.
