Help with Hyundai Accent 1999
15 years 6 months before #13174 by manual-mecanica
Help with Hyundai Accent 1999 published by Manual-Mecanica
I need help, I want to know how to remove the valve stamps of my Hyundai Accent 1999 without removing the camshaft since I do not want to move the time of the same or the cylinder head ,,
15 years 6 months before #13182 by manual-mecanica
Manual-Mecanica Response on the Re: Help with Hyundai Accent 1999
What do you mean with the valve seals explain a little better
15 years 6 months before #13187 by manual-mecanica
It is the seal that carries the valve where the spring is and the insurance and the insurance
15 years 6 months before #13189 by manual-mecanica
It is the seal that carries the valve of the cylinder head where the spring and the insurance is.
15 years 6 months before #13191 by manual-mecanica
Well, there is no other way but disarming what you can do is mark the gear where you unlock it but you would not do anything that you would have to settle the valuables also to do a work to art rule, then you would proceed in point with the adjustment indicated by the builder.-
