consultation
15 years 8 months before #12930 by manual-mecanica
Consultation published by Manual-Mecanica
Hello friends of forum, someone could tell me the dome the chevette distributor model 92 I remove the screw that holds it, but there is something that holds it and does not let it out, it has as a spring, (it seems) from already thank you very much, a greeting to all
14 years 9 months before #19901 by manual-mecanica
Manual-Mecanica Response on the Re: Consultation
Friend, greetings, you have to take out the gasoline pump so you can take out the distributor.
