I can't start my Opel Frontera
15 years 6 months before #12823 by manual-mecanica
I can't start my Opel border published by Manual-Mecanica
I have a problem with the barley of the gas-oil. I prepared to clean the famous GR valve, so it disassembles the shots and loosen the injectors to be able to remove the lid and the valve to clean them. I return to mourn everything but the car does not start. I have read the manual that carries the car and says that for this issue it does not carry bleeding that takes home because it is a bit difficult to be able to tear it out. Could anyone tell me the trick in Question? I can't get it because it is in a garage. It would give all possible help. Thank you
15 years 6 months before #12867 by manual-mecanica
Manual-Mecanica Answer on the Re: I can't start my Opel border
You can bleed the pump first, release the backstrokes and start until it comes out oil without air, then you close them and open or loose the injectors until you entertain the same, after this you start but part you throw it with another vehicle until it starts that it sure. So I exhaust me.
15 years 6 months before #12886 by manual-mecanica
Thanks for answering. I will try it and then I tell you.
