Water oil step in Renault Express 1.4 1996
15 years 6 months before #13091 by manual-mecanica
Repeal the cylinder head with the New Board and you have solved your problem
15 years 5 months before #13469 by manual-mecanica
That is the best k you can approach ... disassemble the cylinder head and ride it with a new meeting ... Ami passed me in a Renault 21 .. very little quantity ... but I cook with a new joint and such ... and problem solved !! greetings!!
15 years 5 months before #13525 by manual-mecanica
Friend David, you will believe that this is the second you see that the cylinder head is changed and the problem still persists .... By chance you know someone who has a repair manual for this model. I would thank you very much. Thanks friend for your tips atte. Pablo
15 years 5 months before #13536 by manual-mecanica
I do not ... is very rare ... k even I have to close the problem persists ... did you plan to be a button and everything? the butt was fine or did you repair it? If everything was fine ... I don't know. I will seek to look for the manual. Greetings! B)
15 years 5 months before #13542 by manual-mecanica
Check the oil heat exchanger, it is mounted on the oil filter, bridge the hoses and change the water and problem solved
